Date/Time: Tue, 10 Nov 2026 05:52:50 +0000
[User Discussion] - 2 instances - Different Volume Data
View Count: 731
| [2020-08-30 14:06:35] |
| User462086 - Posts: 203 |
Instance 1 is set to store tick data (used for charts). Instance 2 is set to store 1 minute data (used for spreadsheets). Otherwise their settings are identical (instance 1's folder was copied/renamed & all the tick based data was replaced with 1 minute bars). Both use the Denali feed and both show the [M] next to the symbol in the region data lines. Using the "Write Bar Data to File" study on 1 minute charts in each instance reveals volume data to be different. SC v2046. How can I get these to match? Many thanks!! |
