Date/Time: Tue, 10 Nov 2026 05:52:47 +0000
Hide menu items/menu customization/keyboard shortcuts
View Count: 1125
[2020-08-30 08:43:48]
TeeJay - Posts: 123
is it somehow possible to hide certain menu items from the main menu, so I can only see the ones I need?
Second question is, if I edit DefaultMenuCustomizations.xml this is not reflected when I start SC. When I customize it from within SC it looks exactly the same as my manual edit, but then is reflected. Why is that?
Is there any possibility to edit shortcuts via an editor? It is extremely time consuming from within SC
Edit : The solution for the second question I found, I forgot to rename the file into MenuCustomizations...
Date Time Of Last Edit: 2020-08-30 09:07:30
