Date/Time: Tue, 10 Nov 2026 05:52:49 +0000
How to change chart background? Change Graphics/Chart background not work.
View Count: 977
| [2020-08-29 01:24:10] |
| User509345 - Posts: 44 |
I copy a chartbook, change chart background not work.
| [2020-08-29 08:22:36] |
| Ackin - Posts: 1865 |
Try: Use Global Graphics Settings Instead of These Settings
Select Chart >> Graphics Settings and enable/disable Use Global Graphics Settings Instead of These Settings to use graphics settings that are specific to the active chart which are set through the Chart >> Graphics Settings window. Enable the Use Global Graphics Settings Instead of These Settings option to use graphics settings that are global and are set through Global Settings >> Graphics Settings window. Graphics Settings: Graphics Settings Controls Date Time Of Last Edit: 2020-08-29 08:25:48
