Date/Time: Tue, 10 Nov 2026 05:52:43 +0000
Can I get a list of Stock Symbols in a CSV File?
View Count: 1343
| [2020-08-28 21:13:41] |
| User473422 - Posts: 20 |
Is there a way to download the list of stocks on each exchange, similar to this page but in a CSV file? https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks |
| [2020-08-28 21:36:25] |
Yes. You can add the symbols to the Associated Watch List: Changing the Symbol of a Chart: Automatically Inserting Symbols for Exchange or Index And then export them: Changing the Symbol of a Chart: Exporting a List of Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-28 21:36:39
| [2020-08-28 23:21:10] |
Close, but by "Associate Watch List" option is grayed out under Chart.
| [2020-08-30 20:24:53] |
| John - SC Support - Posts: 48480 |
The only reason we can think as to why the Associated Watch List would be grayed out is that you do not have a Chart open. Make sure you have an open Chartbook that also has an open Chart in it. Then you should be able to get to the Associated Watch List option.
