Date/Time: Tue, 10 Nov 2026 06:02:57 +0000
numbers bars order fill marker and connecting lines
View Count: 734
| [2020-08-28 21:03:45] |
| User488241 - Posts: 44 |
Hello, It doesn't seem like the global graphics options for color and line width of order fills do not apply to the numbers bars charts. Is there a separate section where you can adjust the colors and widths for order fills in a chart that has numbers bars? Thank you |
| [2020-08-28 21:34:37] |
Order fill connecting lines are not affected by whether you are using the Numbers Bars study or not.
