Date/Time: Tue, 10 Nov 2026 06:02:55 +0000
not connecting
View Count: 861
[2020-08-27 19:50:02]
User386175 - Posts: 31
hi, i am having trouble connecting. please help
Reading Internal Order ID file. | 2020-08-27 12:13:02.079
Reading Trade Orders file. | 2020-08-27 12:13:02.263
Reading Trade Positions file. | 2020-08-27 12:13:02.265
Reading Account Balance file. | 2020-08-27 12:13:02.267
UDPListener (1152). Port 22904 | Listening on UDP port 22904. | 2020-08-27 12:13:02.309
Software version: 2092 32-bit | 2020-08-27 12:13:02.309
Primary Thread ID: 17012 | 2020-08-27 12:13:02.309
Usage end date: 2020-11-02 | 2020-08-27 12:13:02.309
Enabled for: Sierra Chart Historical Data Service. | 2020-08-27 12:13:02.309
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-08-27 12:13:02.309
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-08-27 12:13:02.309
Current selected Data/Trading service: Rithmic Trading | 2020-08-27 12:13:02.309
Custom symbol settings values: disabled | 2020-08-27 12:13:02.309
Chart Update Interval: 500 | 2020-08-27 12:13:02.309
Intraday Data Storage Time Unit: 0 | 2020-08-27 12:13:02.309
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-08-27 12:13:02.309
2020-08-27 12:13:02 Local computer time | 2020-08-27 12:13:02.309
2020-08-27 19:13:02 Local computer time in UTC | 2020-08-27 12:13:02.309
2020-08-27 12:13:02 Local computer time in SC Time Zone | 2020-08-27 12:13:02.309
2020-08-27 19:13:01 Server time in UTC | 2020-08-27 12:13:02.309
Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-08-27 12:13:02.309
Program path: C:\SierraChart\ | 2020-08-27 12:13:02.309
Data Files path: C:\SierraChart\Data\ | 2020-08-27 12:13:02.309
OS Version Number: 10.0 | 2020-08-27 12:13:02.310
Locale Setting: C | 2020-08-27 12:13:02.310
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-08-27 12:13:02.310
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2020-08-27 12:13:02.355
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-08-27 12:13:02.413
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-08-27 12:13:02.516
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-08-27 12:13:02.517
Received 5 login tokens. | 2020-08-27 12:13:02.730
Symbol settings MD5 received. Request ID: 1. | 2020-08-27 12:13:02.915
Symbol settings are up-to-date for rithmic.trading. | 2020-08-27 12:13:02.915
Rithmic Trading | Port for executable: 49568 | 2020-08-27 12:13:07.830
Listening socket (1140). Port 49568 | Closed. | 2020-08-27 12:13:07.830
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:13:07.831
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49568. Current folder: C:\SierraChart\Rim | 2020-08-27 12:13:07.867
Rithmic Trading | Bridge process is running. | 2020-08-27 12:13:09.857
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49568 | 2020-08-27 12:13:09.857
DTC Client socket (1) | Creating socket. | 2020-08-27 12:13:09.857
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:13:09.857
Rithmic Trading | Connected to server. | 2020-08-27 12:13:09.859
Rithmic Trading | Starting socket receive thread. | 2020-08-27 12:13:09.859
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-08-27 12:13:09.859
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-08-27 12:13:09.862
Rithmic Trading | Sending logon request message. | 2020-08-27 12:13:09.862
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-08-27 12:13:09.865
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-08-27 12:13:09.868
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-08-27 12:13:09.868
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-08-27 12:13:10.245
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-08-27 12:13:10.345
Rithmic Trading | Received logon response. | 2020-08-27 12:13:10.345
Rithmic Trading | Server Name: DTC Bridge. | 2020-08-27 12:13:10.345
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-08-27 12:13:10.345
Rithmic Trading | Logon error received from server | 2020-08-27 12:13:10.345
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:13:10.345
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:10.345
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:13:10.377
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-08-27 12:13:10.377
Rithmic Trading | Disconnected. | 2020-08-27 12:13:10.377
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:10.377
Rithmic Trading | Port for executable: 49585 | 2020-08-27 12:13:12.377
Listening socket (900). Port 49585 | Closed. | 2020-08-27 12:13:12.377
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:13:12.377
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49585. Current folder: C:\SierraChart\Rim | 2020-08-27 12:13:12.395
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-08-27 12:13:12.981 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-08-27 12:13:12.982
DTC Client socket (1) | Closed. | 2020-08-27 12:13:12.982
Rithmic Trading | Bridge process is not running! | 2020-08-27 12:13:14.390
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49585 | 2020-08-27 12:13:14.390
DTC Client socket (1) | Creating socket. | 2020-08-27 12:13:14.390
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:13:14.390
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-08-27 12:13:15.392 *
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:13:15.392
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:13:15.392
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:15.392
DTC Client socket (1) | Closed. | 2020-08-27 12:13:15.392
DTC Client socket (0) | CloseSocket call. | 2020-08-27 12:13:15.414
Rithmic Trading | Disconnected. | 2020-08-27 12:13:15.414
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:15.414
Rithmic Trading | Port for executable: 49591 | 2020-08-27 12:13:17.406
Listening socket (1132). Port 49591 | Closed. | 2020-08-27 12:13:17.406
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:13:17.407
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49591. Current folder: C:\SierraChart\Rim | 2020-08-27 12:13:17.425
Rithmic Trading | Bridge process is running. | 2020-08-27 12:13:19.420
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49591 | 2020-08-27 12:13:19.420
DTC Client socket (1) | Creating socket. | 2020-08-27 12:13:19.420
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:13:19.421
Rithmic Trading | Connected to server. | 2020-08-27 12:13:19.422
Rithmic Trading | Starting socket receive thread. | 2020-08-27 12:13:19.422
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-08-27 12:13:19.422
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-08-27 12:13:19.424
Rithmic Trading | Sending logon request message. | 2020-08-27 12:13:19.424
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-08-27 12:13:19.426
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-08-27 12:13:19.429
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-08-27 12:13:19.429
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-08-27 12:13:19.776
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-08-27 12:13:19.875
Rithmic Trading | Received logon response. | 2020-08-27 12:13:19.876
Rithmic Trading | Server Name: DTC Bridge. | 2020-08-27 12:13:19.876
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-08-27 12:13:19.876
Rithmic Trading | Logon error received from server | 2020-08-27 12:13:19.876
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:13:19.876
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:19.876
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:13:19.890
Rithmic Trading | Disconnected. | 2020-08-27 12:13:19.890
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:19.890
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-08-27 12:13:19.890
Rithmic Trading | Port for executable: 49605 | 2020-08-27 12:13:21.893
Listening socket (904). Port 49605 | Closed. | 2020-08-27 12:13:21.893
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:13:21.894
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49605. Current folder: C:\SierraChart\Rim | 2020-08-27 12:13:21.911
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-08-27 12:13:22.521
DTC Client socket (1) | Closed. | 2020-08-27 12:13:22.521
Rithmic Trading | Bridge process is not running! | 2020-08-27 12:13:23.904
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49605 | 2020-08-27 12:13:23.904
DTC Client socket (1) | Creating socket. | 2020-08-27 12:13:23.905
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:13:23.905
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-08-27 12:13:24.906 *
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:13:24.906
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:13:24.906
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:24.906
DTC Client socket (1) | Closed. | 2020-08-27 12:13:24.906
DTC Client socket (0) | CloseSocket call. | 2020-08-27 12:13:24.927
Rithmic Trading | Disconnected. | 2020-08-27 12:13:24.927
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:24.927
Rithmic Trading | Port for executable: 49609 | 2020-08-27 12:13:26.922
Listening socket (904). Port 49609 | Closed. | 2020-08-27 12:13:26.922
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:13:26.923
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49609. Current folder: C:\SierraChart\Rim | 2020-08-27 12:13:26.941
Rithmic Trading | Bridge process is running. | 2020-08-27 12:13:28.939
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49609 | 2020-08-27 12:13:28.939
DTC Client socket (1) | Creating socket. | 2020-08-27 12:13:28.939
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:13:28.939
Rithmic Trading | Connected to server. | 2020-08-27 12:13:28.940
Rithmic Trading | Starting socket receive thread. | 2020-08-27 12:13:28.940
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-08-27 12:13:28.941
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-08-27 12:13:28.942
Rithmic Trading | Sending logon request message. | 2020-08-27 12:13:28.942
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-08-27 12:13:28.945
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-08-27 12:13:28.947
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-08-27 12:13:28.947
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-08-27 12:13:29.300
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-08-27 12:13:29.408
Rithmic Trading | Received logon response. | 2020-08-27 12:13:29.408
Rithmic Trading | Server Name: DTC Bridge. | 2020-08-27 12:13:29.408
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-08-27 12:13:29.408
Rithmic Trading | Logon error received from server | 2020-08-27 12:13:29.408
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:13:29.408
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:29.408
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:13:29.419
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-08-27 12:13:29.419
Rithmic Trading | Disconnected. | 2020-08-27 12:13:29.420
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:29.420
Rithmic Trading | Port for executable: 49623 | 2020-08-27 12:13:31.423
Listening socket (568). Port 49623 | Closed. | 2020-08-27 12:13:31.423
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:13:31.423
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49623. Current folder: C:\SierraChart\Rim | 2020-08-27 12:13:31.441
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-08-27 12:13:32.031 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-08-27 12:13:32.031
DTC Client socket (1) | Closed. | 2020-08-27 12:13:32.031
Rithmic Trading | Bridge process is not running! | 2020-08-27 12:13:33.436
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49623 | 2020-08-27 12:13:33.436
DTC Client socket (1) | Creating socket. | 2020-08-27 12:13:33.436
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:13:33.436
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-08-27 12:13:34.450 *
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:13:34.450
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:13:34.450
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:34.450
DTC Client socket (1) | Closed. | 2020-08-27 12:13:34.450
DTC Client socket (0) | CloseSocket call. | 2020-08-27 12:13:34.472
Rithmic Trading | Disconnected. | 2020-08-27 12:13:34.472
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:34.472
Rithmic Trading | Port for executable: 49626 | 2020-08-27 12:13:36.472
Listening socket (840). Port 49626 | Closed. | 2020-08-27 12:13:36.472
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:13:36.472
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49626. Current folder: C:\SierraChart\Rim | 2020-08-27 12:13:36.491
Rithmic Trading | Bridge process is running. | 2020-08-27 12:13:38.484
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49626 | 2020-08-27 12:13:38.484
DTC Client socket (1) | Creating socket. | 2020-08-27 12:13:38.484
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:13:38.484
Rithmic Trading | Connected to server. | 2020-08-27 12:13:38.486
Rithmic Trading | Starting socket receive thread. | 2020-08-27 12:13:38.486
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-08-27 12:13:38.486
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-08-27 12:13:38.488
Rithmic Trading | Sending logon request message. | 2020-08-27 12:13:38.488
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-08-27 12:13:38.490
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-08-27 12:13:38.492
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-08-27 12:13:38.492
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-08-27 12:13:38.860
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-08-27 12:13:38.970
Rithmic Trading | Received logon response. | 2020-08-27 12:13:38.972
Rithmic Trading | Server Name: DTC Bridge. | 2020-08-27 12:13:38.972
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-08-27 12:13:38.972
Rithmic Trading | Logon error received from server | 2020-08-27 12:13:38.972
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:13:38.972
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:38.972
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:13:39.049
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-08-27 12:13:39.049
Rithmic Trading | Disconnected. | 2020-08-27 12:13:39.049
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:39.049
Rithmic Trading | Port for executable: 49646 | 2020-08-27 12:13:41.054
Listening socket (568). Port 49646 | Closed. | 2020-08-27 12:13:41.054
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:13:41.055
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49646. Current folder: C:\SierraChart\Rim | 2020-08-27 12:13:41.073
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-08-27 12:13:41.583 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-08-27 12:13:41.583
DTC Client socket (1) | Closed. | 2020-08-27 12:13:41.583
Rithmic Trading | Bridge process is not running! | 2020-08-27 12:13:43.063
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49646 | 2020-08-27 12:13:43.063
DTC Client socket (1) | Creating socket. | 2020-08-27 12:13:43.063
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:13:43.064
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-08-27 12:13:44.068 *
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:13:44.068
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:13:44.068
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:44.068
DTC Client socket (1) | Closed. | 2020-08-27 12:13:44.068
DTC Client socket (0) | CloseSocket call. | 2020-08-27 12:13:44.076
Rithmic Trading | Disconnected. | 2020-08-27 12:13:44.076
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:44.076
Rithmic Trading | Port for executable: 49651 | 2020-08-27 12:13:46.080
Listening socket (912). Port 49651 | Closed. | 2020-08-27 12:13:46.080
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:13:46.080
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49651. Current folder: C:\SierraChart\Rim | 2020-08-27 12:13:46.098
Rithmic Trading | Bridge process is running. | 2020-08-27 12:13:48.093
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49651 | 2020-08-27 12:13:48.093
DTC Client socket (1) | Creating socket. | 2020-08-27 12:13:48.093
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:13:48.093
Rithmic Trading | Connected to server. | 2020-08-27 12:13:48.094
Rithmic Trading | Starting socket receive thread. | 2020-08-27 12:13:48.094
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-08-27 12:13:48.095
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-08-27 12:13:48.096
Rithmic Trading | Sending logon request message. | 2020-08-27 12:13:48.096
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-08-27 12:13:48.098
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-08-27 12:13:48.101
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-08-27 12:13:48.101
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-08-27 12:13:48.446
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-08-27 12:13:48.557
Rithmic Trading | Received logon response. | 2020-08-27 12:13:48.557
Rithmic Trading | Server Name: DTC Bridge. | 2020-08-27 12:13:48.557
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-08-27 12:13:48.557
Rithmic Trading | Logon error received from server | 2020-08-27 12:13:48.557
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:13:48.557
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:48.557
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:13:48.568
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-08-27 12:13:48.568
Rithmic Trading | Disconnected. | 2020-08-27 12:13:48.568
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:48.568
Rithmic Trading | Port for executable: 49669 | 2020-08-27 12:13:50.564
Listening socket (880). Port 49669 | Closed. | 2020-08-27 12:13:50.565
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:13:50.565
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49669. Current folder: C:\SierraChart\Rim | 2020-08-27 12:13:50.587
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-08-27 12:13:51.189 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-08-27 12:13:51.189
DTC Client socket (1) | Closed. | 2020-08-27 12:13:51.189
Rithmic Trading | Bridge process is not running! | 2020-08-27 12:13:52.576
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49669 | 2020-08-27 12:13:52.576
DTC Client socket (1) | Creating socket. | 2020-08-27 12:13:52.576
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:13:52.576
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-08-27 12:13:53.578 *
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:13:53.578
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:13:53.578
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:53.578
DTC Client socket (1) | Closed. | 2020-08-27 12:13:53.578
DTC Client socket (0) | CloseSocket call. | 2020-08-27 12:13:53.599
Rithmic Trading | Disconnected. | 2020-08-27 12:13:53.599
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:53.599
Rithmic Trading | Port for executable: 49680 | 2020-08-27 12:13:55.595
Listening socket (912). Port 49680 | Closed. | 2020-08-27 12:13:55.595
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:13:55.595
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49680. Current folder: C:\SierraChart\Rim | 2020-08-27 12:13:55.614
Rithmic Trading | Bridge process is running. | 2020-08-27 12:13:57.608
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49680 | 2020-08-27 12:13:57.608
DTC Client socket (1) | Creating socket. | 2020-08-27 12:13:57.608
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:13:57.608
Rithmic Trading | Connected to server. | 2020-08-27 12:13:57.610
Rithmic Trading | Starting socket receive thread. | 2020-08-27 12:13:57.610
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-08-27 12:13:57.610
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-08-27 12:13:57.612
Rithmic Trading | Sending logon request message. | 2020-08-27 12:13:57.612
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-08-27 12:13:57.614
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-08-27 12:13:57.617
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-08-27 12:13:57.617
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-08-27 12:13:58.027
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-08-27 12:13:58.126
Rithmic Trading | Received logon response. | 2020-08-27 12:13:58.126
Rithmic Trading | Server Name: DTC Bridge. | 2020-08-27 12:13:58.126
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-08-27 12:13:58.126
Rithmic Trading | Logon error received from server | 2020-08-27 12:13:58.126
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:13:58.126
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:58.126
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:13:58.140
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-08-27 12:13:58.141
Rithmic Trading | Disconnected. | 2020-08-27 12:13:58.141
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:13:58.141
Rithmic Trading | Port for executable: 49696 | 2020-08-27 12:14:00.142
Listening socket (1172). Port 49696 | Closed. | 2020-08-27 12:14:00.142
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:14:00.142
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49696. Current folder: C:\SierraChart\Rim | 2020-08-27 12:14:00.161
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-08-27 12:14:00.722 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-08-27 12:14:00.722
DTC Client socket (1) | Closed. | 2020-08-27 12:14:00.723
Rithmic Trading | Bridge process is not running! | 2020-08-27 12:14:02.159
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49696 | 2020-08-27 12:14:02.159
DTC Client socket (2) | Creating socket. | 2020-08-27 12:14:02.159
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:14:02.159
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-08-27 12:14:03.161 *
DTC Client socket (2) | CloseSocket call. | 2020-08-27 12:14:03.161
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:14:03.162
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:14:03.162
DTC Client socket (2) | Closed. | 2020-08-27 12:14:03.162
DTC Client socket (0) | CloseSocket call. | 2020-08-27 12:14:03.171
Rithmic Trading | Disconnected. | 2020-08-27 12:14:03.172
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:14:03.172
Rithmic Trading | Port for executable: 49699 | 2020-08-27 12:14:05.175
Listening socket (876). Port 49699 | Closed. | 2020-08-27 12:14:05.175
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:14:05.176
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49699. Current folder: C:\SierraChart\Rim | 2020-08-27 12:14:05.196
Rithmic Trading | Bridge process is running. | 2020-08-27 12:14:07.190
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49699 | 2020-08-27 12:14:07.190
DTC Client socket (1) | Creating socket. | 2020-08-27 12:14:07.190
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:14:07.190
Rithmic Trading | Connected to server. | 2020-08-27 12:14:07.192
Rithmic Trading | Starting socket receive thread. | 2020-08-27 12:14:07.192
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-08-27 12:14:07.192
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-08-27 12:14:07.193
Rithmic Trading | Sending logon request message. | 2020-08-27 12:14:07.193
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-08-27 12:14:07.195
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-08-27 12:14:07.198
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-08-27 12:14:07.198
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-08-27 12:14:07.564
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-08-27 12:14:07.664
Rithmic Trading | Received logon response. | 2020-08-27 12:14:07.664
Rithmic Trading | Server Name: DTC Bridge. | 2020-08-27 12:14:07.664
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-08-27 12:14:07.664
Rithmic Trading | Logon error received from server | 2020-08-27 12:14:07.664
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:14:07.664
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:14:07.664
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:14:07.671
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-08-27 12:14:07.671
Rithmic Trading | Disconnected. | 2020-08-27 12:14:07.671
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:14:07.671
Rithmic Trading | Port for executable: 49714 | 2020-08-27 12:14:09.674
Listening socket (880). Port 49714 | Closed. | 2020-08-27 12:14:09.674
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:14:09.675
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49714. Current folder: C:\SierraChart\Rim | 2020-08-27 12:14:09.693
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-08-27 12:14:10.289 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-08-27 12:14:10.289
DTC Client socket (1) | Closed. | 2020-08-27 12:14:10.289
Rithmic Trading | Bridge process is not running! | 2020-08-27 12:14:11.713
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49714 | 2020-08-27 12:14:11.714
DTC Client socket (1) | Creating socket. | 2020-08-27 12:14:11.714
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:14:11.714
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-08-27 12:14:12.715 *
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:14:12.716
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:14:12.716
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:14:12.716
DTC Client socket (1) | Closed. | 2020-08-27 12:14:12.716
DTC Client socket (0) | CloseSocket call. | 2020-08-27 12:14:12.718
Rithmic Trading | Disconnected. | 2020-08-27 12:14:12.719
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:14:12.719
Reloading charts due to time zone change. | 2020-08-27 15:14:13.582
Rithmic Trading | Port for executable: 49720 | 2020-08-27 15:14:14.722
Listening socket (1176). Port 49720 | Closed. | 2020-08-27 15:14:14.722
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 15:14:14.723
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49720. Current folder: C:\SierraChart\Rim | 2020-08-27 15:14:14.740
Rithmic Trading | Bridge process is running. | 2020-08-27 15:14:16.736
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49720 | 2020-08-27 15:14:16.736
DTC Client socket (1) | Creating socket. | 2020-08-27 15:14:16.736
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 15:14:16.736
Rithmic Trading | Connected to server. | 2020-08-27 15:14:16.738
Rithmic Trading | Starting socket receive thread. | 2020-08-27 15:14:16.738
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-08-27 15:14:16.738
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-08-27 15:14:16.739
Rithmic Trading | Sending logon request message. | 2020-08-27 15:14:16.739
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-08-27 15:14:16.742
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-08-27 15:14:16.744
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-08-27 15:14:16.744
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-08-27 15:14:17.103
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-08-27 15:14:17.213
Rithmic Trading | Received logon response. | 2020-08-27 15:14:17.214
Rithmic Trading | Server Name: DTC Bridge. | 2020-08-27 15:14:17.214
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-08-27 15:14:17.214
Rithmic Trading | Logon error received from server | 2020-08-27 15:14:17.214
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 15:14:17.214
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 15:14:17.214
DTC Client socket (1) | CloseSocket call. | 2020-08-27 15:14:17.218
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-08-27 15:14:17.218
Rithmic Trading | Disconnected. | 2020-08-27 15:14:17.218
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 15:14:17.218
Rithmic Trading | Port for executable: 49736 | 2020-08-27 15:14:19.222
Listening socket (860). Port 49736 | Closed. | 2020-08-27 15:14:19.223
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 15:14:19.223
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49736. Current folder: C:\SierraChart\Rim | 2020-08-27 15:14:19.242
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-08-27 15:14:19.836 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-08-27 15:14:19.836
DTC Client socket (1) | Closed. | 2020-08-27 15:14:19.836
Rithmic Trading | Bridge process is not running! | 2020-08-27 15:14:21.235
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49736 | 2020-08-27 15:14:21.235
DTC Client socket (1) | Creating socket. | 2020-08-27 15:14:21.235
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 15:14:21.235
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-08-27 15:14:22.238 *
DTC Client socket (1) | CloseSocket call. | 2020-08-27 15:14:22.238
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 15:14:22.238
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 15:14:22.238
DTC Client socket (1) | Closed. | 2020-08-27 15:14:22.238
DTC Client socket (0) | CloseSocket call. | 2020-08-27 15:14:22.249
Rithmic Trading | Disconnected. | 2020-08-27 15:14:22.249
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 15:14:22.249
Rithmic Trading | Port for executable: 49739 | 2020-08-27 15:14:24.251
Listening socket (904). Port 49739 | Closed. | 2020-08-27 15:14:24.251
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 15:14:24.251
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49739. Current folder: C:\SierraChart\Rim | 2020-08-27 15:14:24.271
Rithmic Trading | Bridge process is running. | 2020-08-27 15:14:26.264
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49739 | 2020-08-27 15:14:26.264
DTC Client socket (1) | Creating socket. | 2020-08-27 15:14:26.265
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 15:14:26.265
Rithmic Trading | Connected to server. | 2020-08-27 15:14:26.266
Rithmic Trading | Starting socket receive thread. | 2020-08-27 15:14:26.266
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-08-27 15:14:26.266
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-08-27 15:14:26.268
Rithmic Trading | Sending logon request message. | 2020-08-27 15:14:26.268
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-08-27 15:14:26.270
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-08-27 15:14:26.273
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-08-27 15:14:26.273
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-08-27 15:14:26.671
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-08-27 15:14:26.769
Rithmic Trading | Received logon response. | 2020-08-27 15:14:26.769
Rithmic Trading | Server Name: DTC Bridge. | 2020-08-27 15:14:26.770
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-08-27 15:14:26.770
Rithmic Trading | Logon error received from server | 2020-08-27 15:14:26.770
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 15:14:26.770
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 15:14:26.770
DTC Client socket (1) | CloseSocket call. | 2020-08-27 15:14:26.784
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-08-27 15:14:26.785
Rithmic Trading | Disconnected. | 2020-08-27 15:14:26.785
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 15:14:26.785
Rithmic Trading | Port for executable: 49758 | 2020-08-27 15:14:28.784
Listening socket (568). Port 49758 | Closed. | 2020-08-27 15:14:28.784
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 15:14:28.785
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49758. Current folder: C:\SierraChart\Rim | 2020-08-27 15:14:28.809
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-08-27 15:14:29.363
DTC Client socket (1) | Closed. | 2020-08-27 15:14:29.363
Rithmic Trading | Bridge process is not running! | 2020-08-27 15:14:30.795
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49758 | 2020-08-27 15:14:30.795
DTC Client socket (1) | Creating socket. | 2020-08-27 15:14:30.795
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 15:14:30.796
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-08-27 15:14:31.797 *
DTC Client socket (1) | CloseSocket call. | 2020-08-27 15:14:31.797
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 15:14:31.797
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 15:14:31.797
DTC Client socket (1) | Closed. | 2020-08-27 15:14:31.797
DTC Client socket (0) | CloseSocket call. | 2020-08-27 15:14:31.935
Rithmic Trading | Disconnected. | 2020-08-27 15:14:31.935
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 15:14:31.935
Rithmic Trading | Port for executable: 49760 | 2020-08-27 15:14:33.940
Listening socket (1172). Port 49760 | Closed. | 2020-08-27 15:14:33.940
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 15:14:33.940
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49760. Current folder: C:\SierraChart\Rim | 2020-08-27 15:14:33.958
Rithmic Trading | Bridge process is running. | 2020-08-27 15:14:35.955
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49760 | 2020-08-27 15:14:35.955
DTC Client socket (1) | Creating socket. | 2020-08-27 15:14:35.956
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 15:14:35.956
Rithmic Trading | Connected to server. | 2020-08-27 15:14:35.957
Rithmic Trading | Starting socket receive thread. | 2020-08-27 15:14:35.957
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-08-27 15:14:35.958
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-08-27 15:14:35.959
Rithmic Trading | Sending logon request message. | 2020-08-27 15:14:35.959
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-08-27 15:14:35.961
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-08-27 15:14:35.963
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-08-27 15:14:35.964
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-08-27 15:14:36.318
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-08-27 15:14:36.426
Rithmic Trading | Received logon response. | 2020-08-27 15:14:36.426
Rithmic Trading | Server Name: DTC Bridge. | 2020-08-27 15:14:36.426
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-08-27 15:14:36.426
Rithmic Trading | Logon error received from server | 2020-08-27 15:14:36.426
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 15:14:36.426
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 15:14:36.426
DTC Client socket (1) | CloseSocket call. | 2020-08-27 15:14:36.437
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-08-27 15:14:36.437
Rithmic Trading | Disconnected. | 2020-08-27 15:14:36.437
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 15:14:36.437
Rithmic Trading | Port for executable: 49774 | 2020-08-27 15:14:38.439
Listening socket (876). Port 49774 | Closed. | 2020-08-27 15:14:38.439
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 15:14:38.439
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49774. Current folder: C:\SierraChart\Rim | 2020-08-27 15:14:38.457
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-08-27 15:14:39.046 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-08-27 15:14:39.046
DTC Client socket (1) | Closed. | 2020-08-27 15:14:39.046
Rithmic Trading | Bridge process is not running! | 2020-08-27 15:14:40.466
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49774 | 2020-08-27 15:14:40.466
DTC Client socket (1) | Creating socket. | 2020-08-27 15:14:40.466
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 15:14:40.467
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-08-27 15:14:41.468 *
DTC Client socket (1) | CloseSocket call. | 2020-08-27 15:14:41.468
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 15:14:41.468
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 15:14:41.468
DTC Client socket (1) | Closed. | 2020-08-27 15:14:41.468
DTC Client socket (0) | CloseSocket call. | 2020-08-27 15:14:41.489
Rithmic Trading | Disconnected. | 2020-08-27 15:14:41.489
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 15:14:41.489
Rithmic Trading | Port for executable: 49780 | 2020-08-27 15:14:43.487
Listening socket (876). Port 49780 | Closed. | 2020-08-27 15:14:43.487
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 15:14:43.488
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49780. Current folder: C:\SierraChart\Rim | 2020-08-27 15:14:43.505
Reloading charts due to time zone change. | 2020-08-27 12:14:44.432
Rithmic Trading | Bridge process is running. | 2020-08-27 12:14:45.501
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49780 | 2020-08-27 12:14:45.501
DTC Client socket (1) | Creating socket. | 2020-08-27 12:14:45.501
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:14:45.501
Rithmic Trading | Connected to server. | 2020-08-27 12:14:45.503
Rithmic Trading | Starting socket receive thread. | 2020-08-27 12:14:45.503
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-08-27 12:14:45.503
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-08-27 12:14:45.504
Rithmic Trading | Sending logon request message. | 2020-08-27 12:14:45.504
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-08-27 12:14:45.507
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-08-27 12:14:45.509
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-08-27 12:14:45.509
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-08-27 12:14:45.879
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-08-27 12:14:45.993
Rithmic Trading | Received logon response. | 2020-08-27 12:14:45.994
Rithmic Trading | Server Name: DTC Bridge. | 2020-08-27 12:14:45.994
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-08-27 12:14:45.994
Rithmic Trading | Logon error received from server | 2020-08-27 12:14:45.994
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:14:45.994
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:14:45.994
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:14:46.005
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-08-27 12:14:46.006
Rithmic Trading | Disconnected. | 2020-08-27 12:14:46.006
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:14:46.006
Rithmic Trading | Port for executable: 49794 | 2020-08-27 12:14:48.000
Listening socket (860). Port 49794 | Closed. | 2020-08-27 12:14:48.001
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:14:48.001
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49794. Current folder: C:\SierraChart\Rim | 2020-08-27 12:14:48.019
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-08-27 12:14:48.594 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-08-27 12:14:48.594
DTC Client socket (1) | Closed. | 2020-08-27 12:14:48.594
Rithmic Trading | Bridge process is not running! | 2020-08-27 12:14:50.016
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49794 | 2020-08-27 12:14:50.016
DTC Client socket (1) | Creating socket. | 2020-08-27 12:14:50.016
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-27 12:14:50.016
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-08-27 12:14:51.019 *
DTC Client socket (1) | CloseSocket call. | 2020-08-27 12:14:51.019
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-27 12:14:51.019
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:14:51.019
DTC Client socket (1) | Closed. | 2020-08-27 12:14:51.019
DTC Client socket (0) | CloseSocket call. | 2020-08-27 12:14:51.030
Rithmic Trading | Disconnected. | 2020-08-27 12:14:51.030
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-27 12:14:51.030
Rithmic Trading | Port for executable: 49801 | 2020-08-27 12:14:53.031
Listening socket (876). Port 49801 | Closed. | 2020-08-27 12:14:53.031
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-27 12:14:53.032
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49801. Current folder: C:\SierraChart\Rim | 2020-08-27 12:14:53.050
[2020-08-28 11:04:41]
Based upon what we see it looks as though you need the latest Rithmic bridge files:
Rithmic Bridge Files
[2020-08-28 11:13:11]
the post says to install those in the sierra chart installation folder. i dont know what that is. where should i install them?
[2020-08-28 20:24:26]
The bridge files need to go into the Rim subfolder in the Sierra Chart installation folder.
