Date/Time: Tue, 10 Nov 2026 06:03:04 +0000
Chart tabs frequently reorder themselves within a chartbook
View Count: 979
| [2020-08-26 15:05:38] |
| snillumat - Posts: 29 |
This has been a constant issue for more than a year, maybe longer. I have only one chartbook open consisting of six chart tabs. I manually drag the tabs at the top in the order I prefer. I save the chatbook file. Then, throughout the day, I toggle between the six charts using shortcut keys so I am only viewing one chart at a time. Somehow, the actual order/sequence of the chart tabs changes, seemingly randomly. I then have to reorder the chart tabs. Is there a way to lock the order/sequence of the chart tabs within a chartbook? |
| [2020-08-27 07:04:27] |
We really do not know what is going on in your case and this does not make sense. We can only refer you to: Window, CB and CW Menus: Windows and Chartbooks (Window) There definitely should not be any reordering based upon what you are saying. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-27 07:05:21
