Date/Time: Tue, 10 Nov 2026 06:03:00 +0000
stock float / market cap data
View Count: 1334
| [2020-08-26 04:28:36] |
| jomo88 - Posts: 47 |
Is there anyway to access this kind of data for NASDAQ stocks? NYSE? Historical data would be ideal. Also, I would like to use it inside a study. Is any of this possible? |
| [2020-08-26 21:56:03] |
Not sure about market capitalization. We have to check on that data field to see if we can access it and add it to the data feed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-26 21:57:07
| [2020-08-26 22:02:32] |
Any estimate on time frame for implementation?
| [2020-08-26 23:49:29] |
"Not sure about market capitalization".. does that mean float data is more likely? I am essentially looking to get the weights each stock contributes to the indexes, Nasdaq100 and S&P500, which are calculated by market cap. Maybe the weight data is available directly? (doubtful) I'm surprised more platforms don't have float available... volume traded relative to float is a useful metric for some day traders. |
| [2020-08-27 07:08:14] |
We do not think we are going to be able to offer this. It is something that is an additional cost. It is not easily accessible.
