Date/Time: Sat, 03 Oct 2026 12:58:37 +0000
Missing SCDLLName at the top of CPP file
View Count: 2626
[2020-08-24 15:29:37]
ForgivingComputers.com - Posts: 1239
Rebuilding a CPP file on 2158 that has two SCSF functions, and while it compiles OK, I get the above error next to the DLL file when trying to add the Custom Study.
[2020-08-24 17:58:26]
Sierra Chart - Max - Posts: 5972
Does the file include a SCDLLName line?
Sierra Chart Support
[2020-08-24 18:39:27]
Yes. I attached the file.
[2020-08-24 21:25:42]
This indicates that it is missing that SCDLLName function then. We do not see how this is a problem with version 2158.
[2020-08-24 21:42:11]
Yes, you would think that. However, if I comment out the line, I get this error when trying to build:
-- Starting build of Custom Studies Source files: FC_DJ_Study_Stack_2151.cpp. -- 16:40:02
None of the selected source files contains the SCDLLName() line at the top of the file. Refer to ACSIL documentation.
-- End of Build -- 16:40:02
The line is there. It builds and works fine in 2144. Did you try building it and viewing the Add Custom Study window?
[2020-08-24 21:45:47]
Note that message #1 was the first time I had this problem, and I thought it was due to multiple SCSF functions, but I had it two more times with two other files, including the one I attached.
[2020-08-24 22:13:29]
Now it is working. Not sure why. Will try the other ones that had the issue.
[2020-09-14 12:44:49]
jwick - Posts: 142
Did you gain any clarity on how your problem was resolved? I'm having the same issue after having upgraded to 2164. I have only one SCSF function in my file.
[2020-09-14 14:49:37]
Restarting Sierra and recompiling seemed to fix it.
Brad
