Date/Time: Tue, 10 Nov 2026 06:20:50 +0000
Can't Change Font Size in Volume By Price
View Count: 1513
| [2020-08-15 18:06:21] |
| cmet - Posts: 745 |
When displaying volume related text using VbP study, changing the input on Text Font Size has no effect. Not a big deal, just thought I'd point it out. Version: Pre-release 2151 Date Time Of Last Edit: 2020-08-15 18:07:05
| [2020-08-16 01:28:15] |
There is no problem here. That Input does work correctly. Refer to the documentation for specifically the text you are trying to change the size of.
| [2020-08-16 13:18:14] |
| cmet - Posts: 745 |
In case anyone else wants the actual answer: You don't control font size by using the Text Font Size in Settings and Inputs like you would expect. You actually go to the Subgraphs tab and use the subgraph Volume Numbers Text Color and Size and adjust the Width/Size below. |
