Date/Time: Tue, 10 Nov 2026 06:30:48 +0000
Higher Resolution Chart
View Count: 1570
| [2020-08-13 22:42:53] |
| User94606 - Posts: 327 |
I was given a chartbook but when I opened it on my computer the prices on the x-axis and the time on y-axis along with the labels (font size) are huge. Is there a way to resize the time and price to use the same size as my current chartbooks?
| [2020-08-15 04:51:58] |
Go to that chart and select Chart >> Graphics Settings - Chart. The option for Use Global Graphics Settings Instead of These Settings will be unchecked. Check that box and then OK to close the window and that chart will now be using the Global Graphics that you have setup. Refer to the following for more information: Chart Menu: Graphics Settings - Chart(Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
