Date/Time: Tue, 10 Nov 2026 06:30:55 +0000
studies.cpp index
View Count: 1383
[2020-08-13 21:06:22]
User138418 - Posts: 16
Is there an index? I need source for "Moving Average - Rolling High Accuracy". In which 'studies' file is it located?
[2020-08-14 17:21:07]
ForgivingComputers.com - Posts: 1251
Studies3.cpp
[2020-08-14 19:28:04]
There is not an index that tells you which file contains which studies. But refer to the following to help you find what you are looking for:
How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies
In this particular case, the Moving Average - Rolling High Accuracy study code is in the studies3.cpp file within the /ACS_Source folder under the main Sierra Chart installation.
Date Time Of Last Edit: 2020-08-14 19:28:20
