Date/Time: Tue, 10 Nov 2026 06:30:49 +0000
Can I use 2 separate TWConfig files on the same chart using alert conditions or anything?
View Count: 885
| [2020-08-13 20:39:59] |
| User764809 - Posts: 2 |
Greetings Support, Can I have two separate alert conditions enter their respective trades with two separate TWconfig files tied to them each from the same chart? So basically if I'm say on the 1min chart and an entry setup 1 is entered on a chart then it is assigned TWconfigfile #1 stop settings, where then if a separate entry setup 2 is entered on the same chart then it is assigned a separate TWconfigfile #2? If so, please point me to how this can be achieved I've searched all the documentation and can't figure it out. I know this will likely have to be custom made but if you can guide me on where to go to start doing this that will be greatly appreciated (if it's even possible with SC). |
| [2020-08-14 19:44:39] |
How are you submitting the orders? Are you using an automated trading system?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-14 19:44:49
| [2020-08-14 20:19:25] |
I am using the study "trade system based on alert condition" to submit orders. I assume this needs to be custom programmed but I just want to know where I could look to make sure I get it right in the documentation. |
