Date/Time: Tue, 10 Nov 2026 06:30:45 +0000
Numbers Bars Calculated Values
View Count: 1094
[2020-08-13 19:49:39]
User931593 - Posts: 28
There are 2 Numbers from the study -Numbers Bar Calculated Values that I would like to appear at the top of an up bar and vice versa for a down bar. I have used the Study Subgraph Above/Below Bar as Text, but would like the numbers to appear side by side and show at the top or bottom based on the Base Graph.
Thank you
Date Time Of Last Edit: 2020-08-13 19:50:42
[2020-08-15 04:51:13]
In order to show side-by-side you would have to develop a custom study for this. There is not a built-in study that can do that for you. But, you can have them stacked above/below each other using the existing studies.
Date Time Of Last Edit: 2020-08-15 04:51:18
