Date/Time: Sun, 18 Oct 2026 13:55:12 +0000
CHART BOOK PROBLEM
View Count: 855
| [2020-08-12 11:30:24] |
| User695019 - Posts: 32 |
hello when i open a new chart book i find there is already 2 charts opened that belongs to my other chart book that is also opened. please tell me how to fix this problem and stop charts that belongs to other chartbook showing up on a new one thank you |
| [2020-08-13 19:27:42] |
| John - SC Support - Posts: 48239 |
What you are stating is not the case, if you are opening a new Chartbook, then there are not 2 charts already in it. Most likely, what you are seeing are the charts from the Chartbook that was already open. This can occur if the charts use the option Window Always Visible . Refer to the information here: Window, CB and CW Menus: Window Always Visible (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-16 20:08:23
