Date/Time: Tue, 10 Nov 2026 06:30:49 +0000
Spreadsheet system for trading question
View Count: 713
| [2020-08-11 06:07:15] |
| User804559 - Posts: 22 |
I have the 'Signal Only Once per Bar' set to True. However, it doesn't prevent the system from entering a trade and exiting the same trade within the same bar. I literally want any signal only once per bar. Is there way to achieve this in spreadsheet trading mode? If my entry signal triggers in the current bar, I don't want the exit to trigger in the same bar, it can only trigger in a future bar. |
| [2020-08-11 14:29:15] |
| ForgivingComputers.com - Posts: 1251 |
Add an if statement to your exit formula to see if the entry signal has already been set and only exit if it is 0.
