Date/Time: Tue, 10 Nov 2026 06:20:50 +0000
Trading the MES (micro e-mini sp500) from the ES (e-mini sp500) chart
View Count: 2688
| [2020-08-02 23:53:16] |
| User548243 - Posts: 3 |
Hi Support, Is there a way to trade the MES symbol off or from the ES chart ? A kind of symbol mapping ? I tried to use the <<Trade and Current Quote Symbol>> from Chart - Chart Settings - Main Settings tab but it still trade the ES as shown on the image (I am on a sim account). I would like to see the e-mini chart and trade off of it while the real position or trade would be on the micro e-mini. Tx, Etienne |
| Attachment Deleted. |
| [2020-08-03 03:56:54] |
You have the chart set correctly in regards to that setting. There is nothing more you need to do. Relevant documentation: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) If the profit/loss values are not correct, then refer to: Profit/Loss Calculations and Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-08-16 22:38:56] |
Many thanks for the help. When opening Trade Order Window or Trade Positions window I see that the orders are on the MES. In Chart - Chart Settings - Advanced Settings 2, I did change the Currency Value Per Tick from 12.50 to 1.25. This made the currency display properly in the Trade Window P/L. Again, many thank for pointing to the docs. |
