Date/Time: Tue, 10 Nov 2026 06:30:48 +0000
Found a bug in an included study
View Count: 866
| [2020-08-01 04:32:17] |
| ruiyt - Posts: 11 |
In the "Swing High And Low" study, with the option "Extend Swings Until Future Intersection" enabled. When a new candle is still forming and a swing low or swing high condition is temporarily met, a "line until future intersection" will be drawn. However, when that same candle makes a move that no longer satify the swing high or swing low condition, the lines are still left behind. If you observe the behaviour of the arrows, which indicate a swing high or swing low, the behaviour is correct in that the arrows will disappear when the condition changes. I looked at the source code of the study and determined that there is a simple fix for the problem. You just need to add the following code to delete the line upon every evaluation like so sc.DeleteLineUntilFutureIntersection(indexToEvaluate, 1); sc.DeleteLineUntilFutureIntersection(indexToEvaluate, 2); Subgraph_SwingHigh[IndexToEvaluate] = 0; Subgraph_SwingLow[IndexToEvaluate] = 0; You are welcome. |
| [2020-08-03 16:48:19] |
We will check on this.
| [2020-08-12 00:20:35] |
We apologize for the delay. We will get the study updated.
