Date/Time: Tue, 10 Nov 2026 06:40:57 +0000
Chart Trade Default Order Quantity
View Count: 3175
| [2020-07-29 13:24:51] |
| User255336 - Posts: 28 |
Good morning Sierra Chart, I searched the forums, and tried following instructions according to your documentation, however when I place an order via chart trading, the order quantity entered when the order is placed is still 10000. My Symbol Settings are attached - default quantity is set to 1. Any ideas what I may be missing? Date Time Of Last Edit: 2020-07-29 13:25:09
| [2020-07-30 19:36:51] |
You need to change the Order Quantities on the Trade Window: Basic Trading and the Trade Window: Main/C >> Order Quantity Buttons Basic Trading and the Trade Window: Set >> Button 1-6 Quantity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-30 19:38:09
| [2020-07-30 19:49:56] |
I have done that already - it's currently set to 1. I have taken some screenshots to show you. Even if I manually set the "Order Quantity Limit" to a value of 2, it still puts in an order for 10k. See attached. |
Private File Private File Private File |
| [2020-07-31 01:46:41] |
Please disregard - I have figured this out. I had to add the order window to each one of my charts, and then change the default quantities, and click the "1" to set them all to default to 1.
| [2020-08-02 21:33:42] |
You have different charts with different order quantities in them which is supported. The quantity is not controlled at the symbol level, it is at the chart level. You just need to change the quantity for that one chart. Refer to the information here: Chart Trading and the Chart DOM: Changing Order Quantity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-02 21:34:09
