Date/Time: Sun, 01 Nov 2026 15:38:05 +0000
Adding data fields to the chart value bar
View Count: 1415
| [2014-01-30 21:51:49] |
| mogull - Posts: 40 |
This is an easy one and I used to know how to do it. Searched everywhere in the support board. Add like, the high.low of the bar, etc? Thanks |
| [2014-01-30 22:40:06] |
Global Settings >> Customize Chart Header. There is also Chart >> Chart Settings >> Advanced Settings >> (options you see in the attachment). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-01-31 00:09:15] |
Forgive my ignorance, but the global settings seem to have everything selected, and those settings seem to appear at the top of the chart. I do remember having to go to "advanced settings" and used to see individual fields of what to add, and I don't see them there. (I have seen and done this before, and just don't seem to be able to find it. http://www.sierrachart.com/image.php?l=1391126907335.png That is a screen shot and you can see in the upper left where not much is displayed. |
