Date/Time: Tue, 10 Nov 2026 06:58:58 +0000
[Programming Help] - ACSIL and closing existing order when a condition is met
View Count: 6894
| [2020-07-26 05:23:59] |
| User622324 - Posts: 4 |
In a nut shell: I have an Algo that goes long/short depending on a few criteria. For the sake of this question, I have a few conditions that enable me to enter a long position. Since this is trend following, rather and having a specific take profit and stop loss, my system should remain long UNTIL some criteria is met (i.e. the "STRONG_LONG" becomes "STRONG_SHORT" etc). In the below, I am able to enter positions (and have just tried plotting entries/exits without the actual orders and just using arrows) and that seems to work correctly. My question is around I am unable to "close" the positions and for this I was using `sc.FlattenAndCancelAllOrders()`. I had tried following an example in `TradingSystems.cpp` but had no luck. The pseudo logic I wanted to follow was: - If Position open, are we long? - If we are long and we see a STRONG_SHORT, close and also - If Position open, are we short? - If we are short and see a STRONG_LONG, close In a nut shell, the bottom code under `s_SCTradeOrder ExistingOrder` is what I'm not sure if that's the proper way of doing it. // Use persistent variables to remember attached order IDs so they can be modified or canceled.
int &Target1OrderID = sc.GetPersistentInt(1); int &Stop1OrderID = sc.GetPersistentInt(2); int &r_InternalOrderID = sc.GetPersistentInt(3); s_SCNewOrder NewOrder; NewOrder.OrderQuantity = 1; NewOrder.OrderType = SCT_ORDERTYPE_MARKET; NewOrder.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED; // NewOrder.AttachedOrderTarget1Type = SCT_ORDERTYPE_LIMIT; // NewOrder.Target1Offset = Input_TargetTicks.GetInt() * sc.TickSize; // 8 ticks // NewOrder.AttachedOrderStop1Type = SCT_ORDERTYPE_STOP; // NewOrder.Stop1Offset = Input_StopTicks.GetInt() * sc.TickSize; // 8 tick stop if (IsStrong && concavityState == JN::CONCAV_STATE::STRONG_LONG) { int Result = (int)sc.BuyOrder(NewOrder); if (Result > 0) { Subgraph_BuyEntry[sc.Index] = sc.Close[sc.Index] - Input_OffsetArrowDisplay.GetFloat(); // Remember the order IDs for subsequent modification and cancellation Target1OrderID = NewOrder.Target1InternalOrderID; Stop1OrderID = NewOrder.Stop1InternalOrderID; r_InternalOrderID = NewOrder.InternalOrderID; } else { //Only report error if at the last bar if (sc.Index == sc.ArraySize - 1) { //Add error message to the Sierra Chart Message Log for interpretation sc.AddMessageToLog(sc.GetTradingErrorTextMessage(Result), 1); } } // Subgraph_BuyEntry[sc.Index] = sc.Close[sc.Index] - Input_OffsetArrowDisplay.GetFloat(); } else if (IsStrong && concavityState == JN::CONCAV_STATE::STRONG_SHORT) { // Subgraph_SellEntry[sc.Index] = sc.Close[sc.Index] + Input_OffsetArrowDisplay.GetFloat(); int Result = (int)sc.SellOrder(NewOrder); if (Result > 0) { //If there has been a successful order entry, then draw an arrow // Apply offset so the arrows don't draw on candles Subgraph_SellEntry[sc.Index] = sc.Close[sc.Index] + Input_OffsetArrowDisplay.GetFloat(); // Remember the order IDs for subsequent modification and cancellation Target1OrderID = NewOrder.Target1InternalOrderID; Stop1OrderID = NewOrder.Stop1InternalOrderID; r_InternalOrderID = NewOrder.InternalOrderID; } else { //Only report error if at the last bar if (sc.Index == sc.ArraySize - 1) { //Add error message to the Sierra Chart Message Log for interpretation sc.AddMessageToLog(sc.GetTradingErrorTextMessage(Result), 1); } } } // Get the existing target order, and you basically want this code to run // when we're long and we now get a STRONG SHORT signal or when we're // short and we get a strong long signal // So IF we have an open /working position AND we meet the above critera // Let's just close it. s_SCTradeOrder ExistingOrder; if (sc.GetOrderByOrderID(r_InternalOrderID, ExistingOrder)) { if (IsWorkingOrderStatus(ExistingOrder.OrderStatusCode)) { sc.AddMessageToLog("Open order has been found!", 1); if (ExistingOrder.BuySell == BSE_BUY && concavityState == JN::CONCAV_STATE::STRONG_SHORT) { sc.AddMessageToLog("Closing long due to STRONG SHORT state and current open long!", 1); sc.FlattenAndCancelAllOrders(); } else if (ExistingOrder.BuySell == BSE_SELL && concavityState == JN::CONCAV_STATE::STRONG_LONG) { sc.FlattenAndCancelAllOrders(); sc.AddMessageToLog("Closing short due to STRONG LONG state and current open short!", 1); } } } Date Time Of Last Edit: 2020-07-26 05:25:45
| [2020-07-26 14:49:28] |
| ForgivingComputers.com - Posts: 1251 |
It does not need to be that complex. You want to enable support for reversals, which is off by default. Look here: Automated Trading Management: SupportReversals sc.SupportReversals = EnableReversals.GetYesNo();
| [2020-07-26 17:46:09] |
Hey Bradh, Well so there are ultimately 3 states: long/short/flat I there are times when I want to be able to just be long then close when a calculation meets a criteria. At this point it doesn’t mean I’d want to be short, hence the logic to “flatten and cancel all”. |
| [2020-07-26 17:51:44] |
When in a long trade, a reversal entry (sell signal) will cause the long trade to flatten and the short entry. If you want to test for a different exit criteria, you can do that too, before you check for the reversal.
