Date/Time: Tue, 10 Nov 2026 06:59:07 +0000
Easy to minipulate volume profile
View Count: 793
[2020-07-25 17:05:56]
User425645 - Posts: 123
Hello, TT has a tool that allows one to hover over the amount of Candlestick bars you want for a quick glance volume profile. I was wondering if this was possible in Sierra. I believe the closest thing you have is the visible bar on VBP study but with that you have to constantly change the dimensions of the on screen candlesticks. With TT you can view a whole days worth of candlesticks and highlight 9:30am - 10:30am and show a volume profile for just that hour. It is a little difficult to explain in words please message back if request wasn’t clear.
Thanks for your time.
[2020-07-26 03:00:36]
cmet - Posts: 745
Try Tools > Draw Volume Profile
Allows you to draw a profile by clicking/dragging a box around the bars you want to include.
