Date/Time: Tue, 10 Nov 2026 06:59:05 +0000
Struggling to get a live data feed for US stocks .
View Count: 838
| [2020-07-24 19:43:01] |
| User696740 - Posts: 1 |
I have been trying to activate the correct data feed for all the major US stock markets. Iam a non professional and have signed all the correct forms i hope. Please help because im close to giving up . Thanks John Ingham
| [2020-07-24 22:12:15] |
We will follow-up with you over the weekend in regards to this.
| [2020-07-27 13:49:47] |
| John - SC Support - Posts: 48480 |
We can help you through the process. Let us know if you want us to give you a call or we can work through this thread. If you want to get started, the first thing to do is to enter your country and Futures Broker in this section: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures&UserID=210766#AccountDetails If you do not have a broker, then that is not a problem, just select the option for "Do Not have Futures Broker". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
