Date/Time: Tue, 10 Nov 2026 06:59:01 +0000
Number bars coloring based on daily data percentage
View Count: 741
| [2020-07-24 01:27:30] |
| User200046 - Posts: 1 |
Hello there, I was wondering if there is a way to have number bars background based on AskVol BidVol Difference Percentage of daily data, exactly the same option "Number bars calculated values" already supports. In case this is not currently supported would it be something you'd consider adding in the future? AskVol BidVol Difference - Actual option is great, sometimes it is quite tricky though to determine proper thresholds values, it would be great to have that calculated on a daily data basis. Thanks in advance, regards |
