Date/Time: Tue, 10 Nov 2026 06:59:00 +0000
[Programming Help] - creating a single indicator from the SPX 500 stocks volume and delta data
View Count: 834
| [2020-07-14 05:50:47] |
| endinem - Posts: 4 |
Hi guys! Thanks for your work, the platform is excellent! I would have a conceptual question, and haven't found the answer yet. My goal is to create ONE indicator from all the volume and delta data in stocks for the SPX index. (take the sum of the volumes and the delta (daily) and finally take the ratio of the two). My initial idea was to use spreadsheet study + putting all the stocks in one sector into a single chart (using the add symbol study + volume study + ask volume study). Before I do it just want to make sure if there is any potential limit issue with it: 1. in terms of the number of studies for a single chart 2. number of charts in a spreadsheet study 3. or any other potential issue with the above logic ? In terms of efficiency if there is a better/quicker way to do it please let me know - maybe ACSIL ? Thanks in advance! |
| [2020-07-25 04:58:34] |
| User61576 - Posts: 458 |
No one knows? Its a general question I would also like to know the answer |
