Date/Time: Tue, 10 Nov 2026 07:21:14 +0000
Symbol is unknown (CQG + US Equities via Barchart)
View Count: 1109
[2020-07-13 15:01:02]
seandunaway - Posts: 398
Of course it would be senseless to add every equity symbol to the cqg symbol settings on the server.. but is there a workaround for CQG users also subscribing to equities?
imagesymbol is unknown.png / V - Attached On 2020-07-13 15:00:47 UTC - Size: 115.96 KB - 345 views
[2020-07-14 08:22:54]
In this particular case you just need to install another installation of Sierra Chart to use with the Sierra Chart Exchange Data Feed:
Using Multiple Data and Trading Services at the Same Time
That is the only solution. This is not related to Symbol Settings.
