Date/Time: Tue, 10 Nov 2026 07:31:11 +0000
Possible to save DOM settings?
View Count: 1632
| [2020-07-06 16:37:19] |
| User485623 - Posts: 2 |
Whenever i close my DOM and reopen it the settings revert back to default. Is there a way to save the DOM settings in case I close it by accident? Thanks.
| [2020-07-06 18:47:33] |
You need to have the Trading DOM open when you save the Chartbook. Then when you open the Chartbook the Trading DOM will also open and have the settings as they were previously. Refer to the information here: Chart Trading and the Chart DOM: Saving Trade DOM Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
