Date/Time: Tue, 10 Nov 2026 07:21:17 +0000
what's wrong with my TPO chart?
View Count: 846
| [2020-07-06 13:32:41] |
| Frank Ace - Posts: 12 |
Do you have any idea what is going on with my TPO chart as the attachenment showed? Things frozed on the chart and I cannot move anything incluede scales, I tried to create a new chart but problem remains. Everthing else works fine. |
| [2020-07-07 11:01:05] |
What did you do that caused the problem? We do not know exactly what you did. We recommend starting with a completely new chart. Also refer to: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-07-13 13:00:35] |
I was trying to adjust scale and then it got stuck like what I show you
