Date/Time: Fri, 25 Sep 2026 11:22:15 +0000
Software support
View Count: 1804
| [2013-04-17 17:35:06] |
1. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_GraphicsSettings.html 2. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html On the Targets tab of the Trade Window you will want to to select the "Ticks" option. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-17 17:35:18
