Date/Time: Fri, 13 Nov 2026 16:17:18 +0000
An alert on Percent Change Since Open
View Count: 1488
[2020-07-01 16:00:02]
User266447 - Posts: 280
Dear Sir or Madam,
Could you tell me how to set an alert on an indicator so called. Percent Change Since open, please?
I look forward to hearing from you soon.
Kind regards,
Arek
[2020-07-01 16:08:39]
ForgivingComputers.com - Posts: 1253
Alert formula if the Percent Change Since Open Study (ID1) is Up or Down 50%:
=(ABS(ID1.SG1) >= 0.50)
This will work with any of the "Based on Alert Condition" studies
[2020-07-02 07:34:43]
Refer to the documentation here:
Study/Chart Alerts And Scanning
That page has lots of examples.
[2020-07-02 11:15:30]
Thank you a lot!
I have put the formula into the indicator and now checking for an alert.
Thank you again.
Kind regards,
Arek
[2022-01-20 13:54:29]
Sargon Petros - Posts: 57
I've tried to do this but I get the following in the log
=(ABS(0.009639515541493893) >= 0.50) | No alert sound/email.
Percent change since open shows 0.9 at the time, do I need to run some math on the result before setting the condition?
