Date/Time: Wed, 04 Nov 2026 14:21:26 +0000
Codeweaver Chromebook + Sierra Charts
View Count: 1818
| [2020-06-25 04:37:27] |
| User615508 - Posts: 1 |
I am experimenting to see if Sierra Charts will run via CodeWeavers on Chrome OS, and so far it has started. I'm waiting on trial approval. I don't have any data feed yet because I'm waiting for approval. The only issue I have is that it won't fully scale. I know there are ppl on Linux using Sierra. I hope that i can get it working Chrome OS. Has anyone else tried this?
| [2020-06-25 06:17:12] |
| Sierra_Chart Engineering - Posts: 25374 |
We would not recommend this.
| [2021-02-18 13:55:53] |
| ElmStreetTrader - Posts: 48 |
Hi there, do you not recommend it because it is being implemented on Chrome OS or is it generally not very good? Would it be ok to use on regular desktop version of Linux?
| [2021-02-18 13:58:25] |
At the time the basis of our response would be using another operating system/environment other than strictly Windows. But based on user feedback Running Sierra Chart on Code Weavers Crossover is good on a Mac. This is what we have heard. We cannot speak about Chrome OS. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-18 13:58:46
