Date/Time: Fri, 16 Oct 2026 14:20:06 +0000
SGX Access via TT or CQG?
View Count: 1227
[2020-06-22 16:19:44]
TT46 - Posts: 10
Hello, I'm interested in trading the FTSE China A50 futures on the SGX. I use the SC Order Routing Service via TT to trade the CME markets but noticed that there no connectivity offering SGX, only HKFE. My thinking is that i could use a separate TT API for SGX data and pay.30/side but I use footprint charts a lot.
My backup option is CQG but I would rather not go with them.
What do you recommend is the best way forward to setup SGX data through SC?
[2020-06-22 16:34:47]
TT46 - Posts: 10
For more context, i could setup SGX through CQG via SC through Advantage Futures,
but my understanding is that SC still does not recommend their service?
[2020-06-22 21:28:01]
You definitely are going to need to use CQG. Not TT. CQG is the only reasonable possibility here.
In regards to what we say about CQG, that only applies if you are trading the CME Group of markets.
[2020-06-22 21:45:44]
TT46 - Posts: 10
Thank you for the clarification.
[2022-02-15 01:01:45]
{4D} - Posts: 20
Is it still the case that TT data & routing is not available through SC for SGX?
On another note, it would be brilliant to get SGX added to Denali as it has the most diverse offering of markets out of all the Asian exchanges.
[2022-02-15 15:05:12]
John - SC Support - Posts: 48222
It is still the case that TT data and order routing are not available through Sierra Chart. Do not wait for this to change.
It is doubtful that this will happen.
