Date/Time: Sun, 05 May 2024 02:30:40 +0000
Unhandled exception in Trade DOM
View Count: 1380
[2020-06-26 08:50:32] |
But something has changed in versions later 2111 as I downgraded yesterday and could not reproduce this issue. So this dialog windows was handled differently by Windows in prior SC versions. This is a completely incorrect deduction. We have extensive experience with this. We cannot take the time to provide technical explanations. The order quantity and price dialog has not changed for like about 8+ years. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-26 08:53:22
[2020-06-26 08:55:58] |
nosast - Posts: 290 |
Ok - just strange that this issue came with versions later 2111. It‘s fixed. That‘s only thing important for me ;-) |
[2020-06-26 09:38:46] |
Sierra_Chart Engineering - Posts: 14224 |
If there are no further problems related to this, then our conclusion is correct. Also it is highly highly doubtful there is anything wrong in Sierra Chart which would be causing the behavior that has been reported in this thread.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-26 09:39:01
