Date/Time: Tue, 10 Nov 2026 08:05:12 +0000
Problem with the DOM
View Count: 796
[2020-06-18 10:42:38]
User588930 - Posts: 2
Hi I use the denali data with the latest version, when someone is spoofing , I try get the real Image of the market so I change the number of levels market depth in the chart settings but It doesn't have any effect.
I send you two files of two charts the first one with 50 levels and the second one with 500 but the add of the study is the same.
Is there something that I could do to solve this?
Thanks for your help
Private File
Private File
[2020-06-18 17:31:34]
That setting is for the number of days of Market Depth data to load.
The setting you want is at Chart >> Chart Settings >> Advanced Settings 3 >> Maximum Market Depth Levels.
Refer to the information here:
Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu)
