Date/Time: Tue, 10 Nov 2026 08:05:20 +0000
Update the latest version - issue with chartbook load
View Count: 927
[2020-06-15 23:33:37]
manfretto - Posts: 119
I have updated sierra chart today to the latest version. After the update one of my chartbook cannot load - "The chartbook file requires a newer version of Sierra chart or is not a valid".
Having failed with chartbook load under new version I have also tried to back to the previous version. Not sure if it worked.
I also see that new chartbook backup was created with the name ending ".backup2092". Fortunately, I am able to load this chartbook.
Please let me know if you need any log or action from my side.
Best Regards,
Slawomir
[2020-06-17 11:15:50]
Not sure why there is an issue and we cannot know exactly what you were doing with what version.
To access the backup Chartbook file, refer to:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
[2020-06-17 12:48:00]
ForgivingComputers.com - Posts: 1251
This is supposed your old chartbook with the old file format. If there is a file with the old name, it will be in the new format.
