Date/Time: Tue, 10 Nov 2026 08:21:15 +0000
TPO Charts
View Count: 1050
| [2020-06-15 18:24:31] |
| User969241 - Posts: 155 |
How would I set my TPO chart to display 3 different distributions in 1 day. I want to start 1 distribution at 9:30-16:30 and another from 18-3AM and another from 3AM-9:30. This would display 3 TPO segments in a 24hr period.
| [2020-06-15 19:41:57] |
This is not supported unless you do manual splitting. Otherwise, only two sessions are supported.
| [2020-06-15 21:14:31] |
Ok. I am trying to do manual splitting. I right click the area I want to split but the option for SPLIT isn't available. It is greyed out?
