Date/Time: Tue, 10 Nov 2026 08:21:16 +0000
Surplus data files
View Count: 896
| [2020-06-13 14:05:10] |
| User97684 - Posts: 136 |
Hi, Please help . I use Denali data feed. For trading I used to be on GAin, now with Rithmic. As a result I have 3 sets of the same data files - which can I delete ? Pls see img. Many thanks ! |
| [2020-06-15 01:03:12] |
You just simply delete the chart data files that you are not using. This would be the ones from the past assuming you are not using those and also the ones that do not match the Rithmic symbols. Instructions: Chart Data and Chart Data Files: Deleting a Chart Data File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-06-16 14:14:28] |
Thanks a lot. I will delete all data files but Rithmic's. When the Rithmic support is withdrawn, I will use Sierra with Denali only for charting. Will then Denali install its own data files on my desktop ? Thanks again! |
