Date/Time: Wed, 18 Nov 2026 09:43:22 +0000
Field Marker Size in Version 2118
View Count: 823
| [2020-06-12 23:12:11] |
| User94606 - Posts: 327 |
The field market size in Trade -> Chart Trade Settings defaults to 0. Is this the smallest size? In previous versions the marker size was smaller than the current default. Please advice
| [2020-06-13 00:51:24] |
The smallest size would be 2. Using zero or 1 would default it back to 10.
