Date/Time: Wed, 18 Nov 2026 09:43:15 +0000
MES dom filled ES
View Count: 888
| [2020-06-12 14:02:18] |
| User992714 - Posts: 4 |
I entered a trade on my MES dom but the trade was filled on the ES. I don't understand why this happened or how to fix it so it won't happen again. I trade with ES charts but using the MES dom. Please help
| [2020-06-13 03:57:19] |
You must set that symbol directly on the Chart or Trading DOM you are trading from. Instructions: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
