Date/Time: Fri, 02 Oct 2026 14:35:52 +0000
Receiving bad SecurityDefinitionResponse messages from DTC server
View Count: 988
[2020-06-09 08:44:08]
User442651 - Posts: 25
After sending a SymbolsForExchangeRequest to the server, I start receiving malformed messages amongst the SecurityDefinitionResponse replies, and importantly I never get the final response. Also an excessive number of bytes are being received from the server with each of these messages. Furthermore, when encryption is enabled the client crashes after it is unable to decrypt the server response.
Here is the output from my program. This is using Binary encoding.
Received 388 bytes from server:
message of type: GeneralLogMessage and size: 132
Received 76 bytes from server:
message of type: ExchangeListResponse and size: 76
Received 348 bytes from server:
message of type: SecurityDefinitionResponse and size: 348
security definition for symbol: AUDCAD, description: Australian Dollar / Canadian Dollar
Received 32768 bytes from server:
security definition for symbol: AUDCHF, description: Australian Dollar / Swiss Franc
Received 65536 bytes from server:
message of type: Unknown and size: 0
Received 33296 bytes from server:
Received 2032 bytes from server:
Received 24708 bytes from server:
security definition for symbol: $MYHH, description: YTD Highs Price gt $10
security definition for symbol: $DSDT, description: U.S. Diversified Reits Index
message of type: 28271 and size: 17184
Received 65271 bytes from server:
message of type: 25441 and size: 28787
message of type: 32768 and size: 0
message of type: Unknown and size: 572
message of type: 21845 and size: 20031
Received 64794 bytes from server:
message of type: Unknown and size: 12338
Received 65483 bytes from server:
Received 65430 bytes from server:
message of type: Unknown and size: 88
Received 34251 bytes from server:
Received 26448 bytes from server:
security definition for symbol: N8J21, description: UK Peak Electricity Gregorian Futures (UPL) - LIFFE
Received 7656 bytes from server:
security definition for symbol: MAN21, description: Milling Wheat Futures (WA) - WCE
security definition for symbol: CXU20, description: Containerised White Sugar (CS) - ICE EU / LIFFE
message of type: 25710 and size: 18720
message of type: 63 and size: 32768
message of type: 21320 and size: 0
message of type: 71 and size: 21576
Received 43600 bytes from server:
Sending heartbeat
Received 16 bytes from server:
message of type: Heartbeat and size: 16
[2020-06-09 09:13:53]
You need to check for the problem on your side. That is where the issue is. Make sure you are using the latest header files and data structures.
Date Time Of Last Edit: 2020-06-09 09:14:10
[2020-06-09 15:41:32]
Well, is it normal to be receiving 60,000+ bytes from the server at once (for a message that is supposed to 348 bytes)?
This is a single statement stream read, which can't be "checked" any further.
Also, the message type is at the start of the message header, where I am sometimes getting blocks of zeros. Having out of date structure definitions would not affect that.
[2020-06-09 17:57:02]
Your determination of the message size is incorrect because there is some problem on your side with reading the stream of data.
There could not be anything wrong with this functionality. It is used every day by us handling multiple tens of thousands of security definition messages in seconds.
Date Time Of Last Edit: 2020-06-09 17:57:41
[2020-06-09 18:59:48]
OK. So should I be receiving exactly 348 bytes from the data stream for a SecurityDefinitionResponse?
How about for the GeneralLogMessage? My code determined that 388 bytes were received from server, but the message size encoded in the header is 132. Is it possible the server really sent 388 bytes for this message?
[2020-06-10 00:07:24]
Sierra_Chart Engineering - Posts: 25027
Are you using Binary encoding and not Binary encoding with Variable Length Strings?
With binary encoding the size of messages are fixed and you can use the sizeof operator in the C++ language to check the structure sizes.
There are so many fundamental problems with this question:
It should not even be asked. One problem is, there is no way for us to validate that your conclusion is correct. That is essentially advanced programming help. Which we do not provide. The second problem is that looking at this question in isolation, the server can be sending more data because there are other messages sent at the same time.
The reason it should not be asked is because you should already know that there is no way we can provide any type of proper answer.
This indicates a problem in your code. This should not happen. Furthermore, what is the purpose of telling us this.
[2020-06-10 10:36:43]
norvik_ - Posts: 106
Hi.
100% You have a mistake in your code, receiving buffer overflowing..
[2020-06-11 16:39:00]
Yes, binary encoding. I am using C#, but yes I know how to calculate structure sizes (so if my size #'s are off then there is a problem with the structure definition).
...The second problem is that looking at this question in isolation, the server can be sending more data because there are other messages sent at the same time.
What I meant is that the call to
Stream.ReadAsync
returns 388 bytes in that example, but now you helped me understand that the stream is not necessarily returning one message per read. I will see if that fixes the issue with "bad" messages once I fix this.
This is not "in my code", per se. I simply wrap the socket in an SslStream and the .NET library handles encryption/decryption automatically from there.
It is throwing a common exception that can apparently even be caused by hardware issues. The purpose of telling you this, was that I thought it was at least conceivable that a bad message from the DTC server could be the cause.
[2020-06-11 16:43:20]
norvik_:
Hi.
Yes, there was the error I just mentioned. But how do you know it is buffer overflow? I don't see how there could be buffer overflow, unless there is a bug in the .NET library (i.e. highly unlikely).
[2020-06-11 23:21:46]
Sorry, can't help with dotnet code. I'm using c++ for such things. I don't know exactly which values contains your output, but I had never received packet with size more than 4 kb from SC dtc server. Maybe, there are reason take a sniffer and check real size of packets your app receives?
[2020-06-16 07:27:15]
Everything was fine with the SecurityDefinitionResponse messages once I made the code fix.
I think the packet size is implementation dependent. I have a 65536 byte buffer and made a request to the stream reader accordingly. If my buffer was 4K then I would receive packets of size at most 4k.
The encryption also works fine, and I don't think there was a problem with the code. I believe it was my stack: Either because I was in debug mode in Visual Studio Code, which I have seen cause strange behaviour (unlike MS Visual Studio), or else because before I was running SierraChart on an Ubuntu system using WINE.
