Date/Time: Wed, 18 Nov 2026 09:35:05 +0000
Backup Location
View Count: 964
[2020-06-07 18:41:18]
BADGETT - Posts: 17
I just upgraded to 2115 and see that "auto-magic" backups are going to the regular data folder. I do not like that. How do I get SierraChart to place the backups in the Backup folder the same as in previous versions. Or, better yet, how do I disable auto backups?
[2020-06-07 20:49:34]
BADGETT - Posts: 17
I closed Sierra Chart and restarted it. That fixed the issue.
[2020-06-08 02:50:05]
There is a reason for this. Chartbooks that are in the older format or do not use compression will be saved in the main folder.
