Date/Time: Wed, 18 Nov 2026 09:35:06 +0000
Lock Chart Axis (X+Y)
View Count: 1325
| [2020-06-05 16:51:06] |
| User382737 - Posts: 22 |
Is there a way to do this? The axis currently shift frequently- I am trying to maintain a certain spacing on the price axis and bar size especially.
| [2020-06-08 02:53:02] |
Try using a Constant Range Scale: Chart Scale and Scale Adjusting: Constant Range (Scale Range) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-06-08 18:40:15] |
Is there a way to increase the size (esp. width) of the candlestick bars without changing the horizontal axis values too much?
| [2020-06-10 07:28:32] |
Yes. Refer to: Chart Menu: Decrease Bar Width (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
