Date/Time: Wed, 18 Nov 2026 09:27:10 +0000
[Programming Help] - Region Regen or similar solution?
View Count: 845
| [2020-06-03 07:04:19] |
| Giovanni II - Posts: 25 |
Hi, I have done a new Volume indicator with more informations. I can choose what information the indicator should display for not having too much information on the screen. The problem I have is that if I decide to remove an information from the menu, the indicator continues to show it for the previous candles.. to remove the information from the region of the indicator I have to give the command Chart -> Reload and Recalculate.. Is there one more quick way to get the same result without having to manually run the command every time I want to add or remove informations from the indicator? //This is the basic framework of a study function. Change the name 'TemplateFunction' to what you require.
SCSFExport scsf_Volume2(SCStudyInterfaceRef sc) { SCSubgraphRef Subgraph_Volume = sc.Subgraph[0]; SCSubgraphRef Subgraph_Delta = sc.Subgraph[1]; SCSubgraphRef Subgraph_MediaVolumi = sc.Subgraph[2]; SCSubgraphRef Subgraph_MediaDelta = sc.Subgraph[3]; SCSubgraphRef Subgraph_MoltDelta = sc.Subgraph[4]; SCSubgraphRef Subgraph_MoltVolumi = sc.Subgraph[5]; SCSubgraphRef Subgraph_MoltDelta2 = sc.Subgraph[6]; SCSubgraphRef Subgraph_MediaAsk = sc.Subgraph[7]; SCSubgraphRef Subgraph_MediaBid = sc.Subgraph[8]; SCSubgraphRef Subgraph_MoltAsk = sc.Subgraph[9]; SCSubgraphRef Subgraph_MoltBid = sc.Subgraph[10]; SCInputRef BarreV_Si = sc.Input[1]; SCInputRef BarreD_Si = sc.Input[2]; SCInputRef MediaV_Si = sc.Input[3]; SCInputRef Media_Volumi = sc.Input[4]; SCInputRef Molti_Volumi = sc.Input[5]; SCInputRef MediaD_Si = sc.Input[6]; SCInputRef Media_Delta = sc.Input[7]; SCInputRef Molti_Delta = sc.Input[8]; SCInputRef MediaAsk_Si = sc.Input[9]; SCInputRef Media_Ask = sc.Input[10]; SCInputRef Molti_Ask = sc.Input[11]; SCInputRef MediaBid_Si = sc.Input[12]; SCInputRef Media_Bid = sc.Input[13]; SCInputRef Molti_Bid = sc.Input[14]; if (sc.SetDefaults) { sc.GraphName = "Volume 2"; sc.ValueFormat = 0; sc.AutoLoop = true; sc.ScaleRangeType = SCALE_ZEROBASED; Subgraph_Volume.Name = "Volume"; Subgraph_Volume.DrawStyle = DRAWSTYLE_BAR; Subgraph_Volume.AutoColoring = AUTOCOLOR_BASEGRAPH; Subgraph_Volume.PrimaryColor = RGB(0, 128, 0); Subgraph_Volume.SecondaryColor = RGB(147, 0, 0); Subgraph_Volume.DrawZeros = false; Subgraph_Volume.LineWidth = 2; Subgraph_Delta.Name = "Volume Delta"; Subgraph_Delta.DrawStyle = DRAWSTYLE_BAR; Subgraph_Delta.AutoColoring = AUTOCOLOR_POSNEG;//in funzione del valore negativo o positivo Subgraph_Delta.PrimaryColor = RGB(0, 255, 0); Subgraph_Delta.SecondaryColor = RGB(255, 0, 0); Subgraph_Delta.DrawZeros = false; Subgraph_Delta.LineWidth = 2; Subgraph_MediaVolumi.Name = "Media Volumi"; Subgraph_MediaVolumi.DrawStyle = DRAWSTYLE_DASH; Subgraph_MediaVolumi.PrimaryColor = RGB(0, 128, 255); Subgraph_MediaVolumi.DrawZeros = false; Subgraph_MediaVolumi.LineWidth = 2; Subgraph_MediaDelta.Name = "Media Delta"; Subgraph_MediaDelta.DrawStyle = DRAWSTYLE_DASH; Subgraph_MediaDelta.PrimaryColor = RGB(255, 128, 0); Subgraph_MediaDelta.DrawZeros = false; Subgraph_MediaDelta.LineWidth = 2; Subgraph_MediaAsk.Name = "Media Ask"; Subgraph_MediaAsk.DrawStyle = DRAWSTYLE_LINE; Subgraph_MediaAsk.PrimaryColor = RGB(0, 250, 0); Subgraph_MediaAsk.DrawZeros = false; Subgraph_MediaAsk.LineWidth = 2; Subgraph_MediaBid.Name = "Media Bid"; Subgraph_MediaBid.DrawStyle = DRAWSTYLE_LINE; Subgraph_MediaBid.PrimaryColor = RGB(250, 0, 0); Subgraph_MediaBid.DrawZeros = false; Subgraph_MediaBid.LineWidth = 2; Media_Volumi.Name = "Periodo Media Volumi"; Media_Volumi.SetInt(5); Media_Delta.Name = "Periodo Media Delta"; Media_Delta.SetInt(5); Molti_Delta.Name = "Moltiplicatore Media Delta"; Molti_Delta.SetInt(3); Molti_Volumi.Name = "Moltiplicatore Media Volumi"; Molti_Volumi.SetInt(1); MediaV_Si.Name = "Media Mobile Volumi?"; MediaV_Si.SetYesNo(1);//1 = Yes, 0 = No MediaD_Si.Name = "Media Mobile Delta?"; MediaD_Si.SetYesNo(1);//1 = Yes, 0 = No BarreV_Si.Name = "Barre Volume?"; BarreV_Si.SetYesNo(1);//1 = Yes, 0 = No BarreD_Si.Name = "Barre Delta?"; BarreD_Si.SetYesNo(1);//1 = Yes, 0 = No MediaAsk_Si.Name = "Media Mobile Ask?"; MediaAsk_Si.SetYesNo(1);//1 = Yes, 0 = No MediaBid_Si.Name = "Media Mobile Bid?"; MediaBid_Si.SetYesNo(1);//1 = Yes, 0 = No Media_Ask.Name = "Periodo Media Ask"; Media_Ask.SetInt(5); Media_Bid.Name = "Periodo Media Bid"; Media_Bid.SetInt(5); Molti_Ask.Name = "Moltiplicatore Media Ask"; Molti_Ask.SetInt(1); Molti_Bid.Name = "Moltiplicatore Media Ask"; Molti_Bid.SetInt(1); return; } Date Time Of Last Edit: 2020-06-03 07:05:01
