Date/Time: Wed, 18 Nov 2026 09:24:59 +0000
May I have an example study for setting sc.AutoScalePaddingPercentage?
View Count: 929
| [2020-06-02 23:12:35] |
| User497913 - Posts: 6 |
I have tried to set this in my study but it does not do anything. Below is the code if (sc.MenuEventID == ACS_BUTTON_2)
I am not looking for programming help. I think this variable does not work as described.{ const int ButtonState = (sc.PointerEventType == SC_ACS_BUTTON_ON) ? 1 : 0; if (ButtonState == 1) { sc.SetCustomStudyControlBarButtonEnable(ACS_BUTTON_2, 0); sc.AutoScalePaddingPercentage = -0.08f; } } Can you give an example study like those in Studies.cpp? Thanks. |
| [2020-06-04 06:51:42] |
Are you trying to set this variable on the study or on the main price graph? Refer to: ACSIL Interface Members - Variables and Arrays: sc.BaseGraphAutoScalePaddingPercentage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-04 06:52:48
| [2020-06-05 13:42:23] |
They are the same for my study, because sc.GraphRegion is set to 0. I have tried sc.BaseGraphAutoScalePaddingPercentage as well but still nothing happens on the scale.
| [2020-06-05 23:25:43] |
Setting that to a nonzero value definitely does change the scale of the main price graph. Try setting it to .5. It is very reliable.
