Date/Time: Wed, 18 Nov 2026 09:25:03 +0000
LE Q0
View Count: 832
| [2020-06-02 17:42:41] |
| User357195 - Posts: 204 |
SC: For some reason, when I try to place an order for Live Cattle, symbol LE Q0, from the Sierra Chart or from the DOM I get a notice that "trading account is not active." My account is active. Also, I can place an order for HE lean hogs, for NQ, for CL, for 6E or for any other symbol and the orders go live and fill with no problems. I am using a Rithmic feed and I am a OneUp Trader. Do you have an idea why only LE, live cattle shows that notice and does not allow the order to go live? Thanks in advance. I think Sierra Charts are the best. |
| [2020-06-04 05:37:52] |
That is going to be an error from the Rithmic system. So you need to contact OneUp Trader about this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-04 05:38:07
