Date/Time: Wed, 18 Nov 2026 09:19:02 +0000
Any way to transfer the Graphics Settings - Global?
View Count: 1573
| [2020-06-01 09:43:41] |
| Giovanni II - Posts: 25 |
Hi, I just done the Pc configuration and saved it with a name, now I would transfer it on my laptop, is there a way to do this with a file copy? Not the whole Sierrachart because the charts configurations on the PC are differrent from the laptop configurations because of the 3 monitors I have on the PC. Thank's Piero |
| [2020-06-01 10:32:38] |
Refer to help topic 15 for the file that contains this : Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
