Date/Time: Wed, 18 Nov 2026 09:19:01 +0000
Automated trading based upon outside alerts
View Count: 1378
| [2020-06-01 06:43:33] |
| user8222 - Posts: 21 |
is it possible to place trades in sierra based upon conditions that happen in external programs(i.e. tradingview.com alert)? I have systems that are not compatible with sierra but are coded into tradingview for example.
| [2020-06-01 09:16:53] |
| Ackin - Posts: 1866 |
Signals from Sierra to external? or vice versa? it is possible to load zones from a text file. If you don't trade scalp but swing trades, that should be enough |
| [2020-06-01 14:55:15] |
Signals to sierra from external.
| [2020-06-01 15:25:20] |
Extending horizontal levels and line levels if you send me a sample of your output on our CZSK forum, it is possible to process the study more for your purposes ... It's up to you, if you are interested, register there and put a screen there, then we can create a more efficient process together. |
| [2020-06-01 17:31:06] |
No this is not supported. For automated trading, refer to: Automated Trading Management Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
