Date/Time: Wed, 18 Nov 2026 09:19:03 +0000
[User Discussion] - Draw Horizontal lines at High/Low of Profile
View Count: 1053
| [2020-05-31 19:33:15] |
| Bruce - Posts: 50 |
support maybe i missed it, is there away to draw horizontal lines at the high and low of a profile until intercepted!
| [2020-05-31 22:54:18] |
| User48838 - Posts: 134 |
Isn't the high/low of a profile, the high/low for current session? That study would be DHLC.
| [2020-06-01 05:47:01] |
| Bruce - Posts: 50 |
Not on a 4 hour profile!
| [2020-06-01 09:12:09] |
| Ackin - Posts: 1866 |
when you have chart time based study Highest High/Lowest Low Over N bars when you have chart non time based chart based on time (days-mins-secs per bar) with settings (0-60-0) then study Highest High/Lowest Low Over N bars with settings "4" and result Study/Price Overlay to your chart |
| [2020-06-01 11:41:50] |
| Bruce - Posts: 50 |
Thanks for your help, but not the desired results. If support already have "Draw Profile Outline Enclosing Bars" Why can't they have "Draw Horizontal Lines" at The High & Low of any Profile. Including extend until intercepted. What about It Support? Thanks |
| [2020-06-01 11:57:54] |
Well, last thought: VAL, VAH Percentage 100% (IN56), Until future lines (IN55) |
| [2020-06-01 13:49:39] |
| Bruce - Posts: 50 |
Thanks That worked!
| [2020-06-01 13:53:31] |
Thanks That worked!
Yes, but you will lose the opportunity to have VAL, VAH .... I was just looking for a solution quickly, if there is no other option ...But I'll give +1 to your original support request by adding this option to the profile volume as an additional item. It would be nice there. |
| [2020-06-01 14:48:50] |
| Bruce - Posts: 50 |
The only other thing I can do now is duplicate VBP and put the VA at 70%
Date Time Of Last Edit: 2020-06-01 14:49:15
