Date/Time: Wed, 18 Nov 2026 09:09:13 +0000
Starting market replay fails
View Count: 805
| [2020-05-24 10:19:40] |
| User46930 - Posts: 28 |
Tried two times, it gets stuck at about 28% Check the screenshot attached |
| [2020-05-24 22:57:22] |
There would seem to be something wrong with that Intraday chart data file for the chart. We want you to follow the instructions here to delete that file: Chart Data and Chart Data Files: Deleting a Chart Data File Once deleted, and you reopen the Chartbook, fresh data will be downloaded. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
