Date/Time: Wed, 18 Nov 2026 08:54:55 +0000
Why i dont get live update?
View Count: 810
| [2020-05-20 17:43:14] |
| User466167 - Posts: 3 |
just paid 26$ for the sierra charts to run and i don't get live trading charts or DOM in real time! why is that? why im not able to run a market profile? what plan i need to have for market profile? |
| [2020-05-20 19:19:20] |
With regards to the Live Data, refer to the information here: Is Historical and Real-time Data Included? With regards to the Market Profile, you need to be on Package 5. Right now you are on Package 3. Refer to the information here for the differences between the packages and their cost: Description of Service Packages and Pricing: Packages To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
